often should i do the servicing.
Old Nov 5, 2006 | 07:00 AM
ameersak's Avatar
Default often should i do the servicing.
hi.just wanted to know how often should these be done by myself..i mean, after how many kms shall i replace both brake oil (rear and front), coolant, lubricating the chain and other minor servicing.
thanx.
ameer.
Old Nov 5, 2006 | 10:50 AM
gixxereater's Avatar
Default RE: often should i do the servicing.
Oil/filter I change around every 3500 miles or so. Let be honest, most bull**** about this 1000 miles changes are lies. Always change filter with oil. Chain.......you'll know. My 900RR chain lasted 20K. Brake fluid, I have never changed the rear, and the front I did when it started getting sticky and not operating smooth anymore. Basically I change the oil, lube the chain, check the tires pressure quite often. As for the coolant, brake fluid, spark plugs, air filter, I did all that stuff at once at 20K myself. That is all I've ever done in the way of service.
Old Nov 5, 2006 | 01:14 PM
Dave K's Avatar
Since I ride more than one motorcycle, I change oil every 2000 miles or once a year, which ever comes sooner. Brake fluid, I change every other year. Chains, I oil every other tank, (still old habit from before "O" ring chains). Coolant, about every 4 years. Airfilter, I check and or replace about every 7500 miles
Old Nov 5, 2006 | 01:59 PM
N8 Dawg's Avatar
The chain I usuall oil about once a month to every 3 weeks. I change the oil every 3k miles. I changed the brake fluid in the front at 13k becuase I took my calipers apart, the rear I have never done. Some people replace there plugs at the begining of the riding season, I am going to replace mine every other year.
20k miles on the same air filter, man that must have been dirty! I replace mine every year, but when the farmers are getting their crops, I usually have to change it then becuase of all the dust.
Old Nov 5, 2006 | 05:12 PM
Same air filter because it's a K&N. I cleaned it at 6k and then again at 20k. Might be a long time, it wasnt really very dirty though.
Old Nov 6, 2006 | 01:15 AM
ameersak's Avatar
thank you all people! cheers!
ameer.
roys654
Dec 26, 2009 04:22 PM
MrSplean
Jan 22, 2009 06:57 PM
TundaDrive
Apr 10, 2007 01:07 PM
[RXT35Y]
Sep 12, 2006 09:46 AM
Triangle
May 22, 2006 09:50 AM
