not holding a charge
Old Apr 28, 2009 | 01:02 PM
khangkou's Avatar
Default not holding a charge
i got a 93 cbr 600 and its not holding a charge, i already changed the rectifier, and the headlights is always on high beam, wanted to know what i could do about the battery and the headlights, would it be a easy fix?
Old Apr 28, 2009 | 03:26 PM
stuntridef4i's Avatar
Did you check the stator? I have a f4i and it wasnt holding a charge but when I checked for cotunuity on the stator it turned out a wire in side broke lose.
Old Apr 28, 2009 | 05:35 PM
skoobydoobie's Avatar
Read the stickys
Old Apr 29, 2009 | 12:50 PM
khangkou's Avatar
i checked out the stator and it seems fine none of the wirer broke off that i notice but i'll probably install a new just to see if its the issue
Old Apr 29, 2009 | 05:55 PM
Default battery
If you have a manual it will tell you what type of readings you should be getting for cotunity to see if the stator is properly working. If you do that it will save you money before you go replacing it. At least then you would know if it was that or not.
Old Mar 21, 2011 | 08:11 AM
BngWtr's Avatar
Default not holding a charge and eventually loss power to engine
I have a 96 cbr 600 f3 and as of recent have had some issues maintaining batt pwr. i can charge my batt to 14volts but the second im off the the charger and go for a little drive, the bike will evemtually lose pwr and the engine dies. essentially tee bike no longer provises a charge to the batt while running... any ideas???
Old Mar 21, 2011 | 11:27 AM
Shadow's Avatar
Reg/rectifier is faulty or a fried battery.
Put a tester on it under load.
Should give you 13.5V-15.5V at 3000 RPM.
Old Mar 21, 2011 | 08:39 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Fault Finding Flow Chart for Motorcycle Charging Systems
Old Mar 25, 2011 | 08:46 AM
BngWtr's Avatar
I will give the flow chart a shot over the weekend... thanx for the post...
i should also mention that when i disconnectected the stator plug in the r/r, i found one of tje female cpnnectors burnt out
JonezyWyo
May 5, 2013 06:34 PM
matt56us
Nov 23, 2011 02:12 PM
khangkou
Apr 29, 2009 07:34 PM
IwannaCBR
Apr 23, 2007 10:53 PM
Versatilx1
Apr 6, 2006 03:57 PM
