No Luck!!
Old Jan 22, 2009 | 03:56 PM
rozzzy's Avatar
Default No Luck!!
Well I put the plugs back in and had the same results as before it just keeps turning over but not starting thenocasionally backfires really loud....should i just let it sit till tomorrow and see what happens? I am so confused because I rode it all day yesterday and it rode just fine and started just fine everytime...any advice would be great thanks!!!
Old Jan 22, 2009 | 05:47 PM
CB750's Avatar
Default RE: No Luck!!
Could you do us a big favor and put all you posts in one thread? It would help to not confuse us.I had to go back and re-read both your other threads to figure out what you did.
You probably have the plug wires on the wrong plugs.
How long did you leave the plugs out? A couple hours is a good start, overnight is better. Also, make sure your plugs are dry, wet plugs don't spark.
Old Jan 22, 2009 | 05:53 PM
DWT74's Avatar
Did you spin the motor over when you had the plugs pulled? I use to own a F2 but cant remember if the bike will spin over with the kill switch off, if it will then do that. Make sure to let it dry out and when you go to crank it that you choke it and dont throttle it at all. Just pull the choke back turn the switch on and let it start on its own. They are cold natured bikes and its winter time so it is worst. May even need to put the battery on charge a few hrs before you crank it. Hope this helps.
Old Jan 22, 2009 | 05:55 PM
DWT74's Avatar
Do as CB750 said keep it at this thread it will help us out, i had to do the same as him and reread your post, Just trying to help.
Old Jan 23, 2009 | 01:14 AM
justasquid's Avatar
You need to buy a new set of plugs. Once those type of plugs foul, toss em. Make sure you buy a set of NGK's. My F3 did not perform at all with champions. The NGK'sare pricey plugs, but thats what that bike needs.
And as already said by DWT74,make sure your battery is fully charged. That bike needs to be cranking over fast or you will just foul out the new set of plugs.
gtcole
Jul 30, 2013 10:06 PM
Dluv35
Nov 3, 2008 11:55 PM
voodoochyl
Feb 26, 2008 10:15 AM
Dj_Squatch
Feb 12, 2008 11:16 AM
JZHALES
May 13, 2007 01:44 AM
