New User needs help
Old Jul 9, 2012 | 04:52 PM
chritchell's Avatar
New Member
Default New User needs help
Hi all,
Good to become a member.
I have a CBR 600f4 1999. Love it!
I have just replaced the indicators with some nicer little LED jobs. The old flashers werethe only thing that made my bike look older. Just fitted the relay to make these flash at the correct speed - but guess what - I also managed to mess something else up.. Since sitting the relay, my bike will not idle and cuts out, even with choke fully open. I may have plugged the relay in to the wrong place first (the connection next to the flasher relay).
Can anyone help? Feel like I have fried some electrics or something//?!
Cheers,
Chritchell
Old Jul 9, 2012 | 07:12 PM
zaqwert6's Avatar
Nov 2011 ROTM
Check the fuses first and see if you blew something. Also make sure you didn't purposely or accidently unplug something around the areas you worked. I guess I'd start there.
Old Jul 9, 2012 | 07:24 PM
CJardine's Avatar
Track junkie & modaholic
Yea check your relays, I just discovered that I did the same thing. Bike would turn over and over. What did the relay look like what angle did the connection come out at. The relay right next to the flasher relay is the fuel cut off relay and that will keep your bike from starting
Old Jul 10, 2012 | 08:34 AM
marc0011's Avatar
I would plug in the relay you removed and see what happens. If the bike runs without a problem, you removed the incorrect relay.
Old Jul 10, 2012 | 10:40 AM
chritchell's Avatar
New Member
Cheers guys, the CBR is alive again - started up first time after I went to undo my previous mistakes.
-I must have somehow managed to plug the fuel relay to the flasher circuit and the flasher relay to the fuel!! (oops)
jhag09
Apr 30, 2013 03:34 AM
Daimo
Nov 14, 2011 12:23 PM
jboles5472
Mar 22, 2011 03:01 PM
hipong
Jun 11, 2010 12:00 PM
91600f2
Apr 5, 2008 03:43 PM
