new cylinder hd ,valve adj question NEED HELP!!!
got a new used cyl hd with valves & cam shafts and cover all in one ,put on bike and
went to size valves , 6 of the valves i couldnt get a feeler in, the other ones
were within tolerance 3 on the intake side and 3 on the exhaust side, is this
something that happens swapping hds off of other
bikes ? the head had 7000miles on it and i wouldnt think it should be this far out
could it be something im doing wrong? if im off by a tooth on the cam shaft to the chain
could this cause this? need some advice
its a 2000 cbr600f4 swapped heads because when i went to do a valve adj
1 of the journals were scored bad so with all the feed back from all of you i decided to get a used hd off of ebay
