Need help for tomorrow project. I'm so stupid
Old Mar 26, 2005 | 01:19 AM
F3inPieces's Avatar
Default Need help for tomorrow project. I'm so stupid
i have a 97 cbr f3 and the battery is almost dead and not accepting a charge but once I jump the bike it would stay running, PROBLEM: I went to try and jump it today from my car, and I reversed the polarities on the cables and lost all power from the bike. What do I do. I checked all of the fuses on the right front side of the bike...Is there another fuse box...I am Lost!!!!Help, I wanna right tomorrow. Please help the newbie
Old Mar 26, 2005 | 01:22 AM
homer319's Avatar
Default RE: Need help for tomorrow project. I'm so stupid
I am not a big bike mechanic (yet) but if it is anything like a vehicle, when you cross your cables, you just drained the battery of anything that was left in it. If it is not holding a charge, you need to determine what the problem is and fix it. When you have a problem like that and you don't fix it, it only gets worse. Then when you need it to start the most, like away from your house, it won't. I would check the alternator to make sure it is charging and if so, I would replace the battery.
Old Mar 26, 2005 | 01:27 AM
F3inPieces's Avatar
I hope youre right, I will try it in the morning, I already took the battery out just cause I thought that might be it, I believe the alternator is ok because it was boosting the dead battery a little from about an hour of runtime. Thanks for the help.
Old Mar 26, 2005 | 01:37 AM
beater 900rr's Avatar
you may have already cheaked but cheak fuse # 21 in this link micro fitch
sorry about the bad link but it is the same fuse mhcbrf2 was talking about
Old Mar 26, 2005 | 01:57 AM
mhcbrf2's Avatar
I am not sure on your year but a lot of bikes have one high amp fuse at the end of the POS + cabel. Just in case of a dead sort like crossing cabels.
Old Mar 26, 2005 | 03:17 PM
chainstretcher's Avatar
Admin Emeritus & MVN
When you reversed the cables did you actually press the start button? If not then you just killed your battery. A motorcycle battery is no match for a car battery and there are ways to kill one. So get a new battery and see what happens.
Now the chastisement: Running a low battery on a modern sportbike is bad idea. To save weight (and rotational mass) the generator's on our bikes are tiny. The 1000RR only puts out 340watts at 5000rpms. Not enough to run a hairdryer. So your battery is always charging and discharging while the bike is running. A very weak battery can, at best make the bike run goofy and at worst leave your *** stranded on the side of the road. Walking sux.
Good luck -- I don't think you screwed anything up except maybe the old battery.
Old Mar 26, 2005 | 04:46 PM
L8X's Avatar
L8X
I'm curious to hear what happened after you put in a fresh battery. I've come close to crossing wires before but always catch myself. Please let us know in case we need the info in the future.
Old Mar 26, 2005 | 11:16 PM
F3inPieces's Avatar
All of the responses assisted me in one way or another, I found the fuse on the positive terminal which was blown, I put in a new battery and things woked perfectly, thanks for all of the help.
Old Mar 27, 2005 | 12:49 AM
mhcbrf2's Avatar
Glad to hear your back on the road.
TimBucTwo
The Hurricane Saloon
26
Nov 2, 2013 08:02 PM
Taiden
Dec 26, 2009 04:38 PM
MartiniRossy
Jun 11, 2009 02:42 PM
dwschultzy
Dec 3, 2007 08:47 AM
adams_CBR600f2
May 22, 2007 03:18 AM
