Need help replacing right foot bracket.
Old Jan 9, 2009 | 12:45 PM
daazndood's Avatar
Default Need help replacing right foot bracket.
Hey guys. the previous owner carved stupid numbers on the right foot bracket so I bought a better condition one to swap out. it looks like this.
the question is, the brake pedal is attached to this from the back. Dont i have to disengage the brake system or anything like that? If i try to remove the foot bracket without doing anything to the brakes, the whole system might get screwd up right? how do i do this right?
Old Jan 9, 2009 | 01:52 PM
justasquid's Avatar
Default RE: Need help replacing right foot bracket.
You should be able to unclip or unbolt everything. The cylinder's shafthas a pin with a clip holding it onto the brake pedal. You can remove that first, then everything else and just swap it all over to the new assembly.
Im not sure what you mean by messing the system up. Everything can be adjusted once you get the bracket on if its needed. As long as you dont remove any lines, you wont have to bleed anything.
Old Jan 9, 2009 | 11:15 PM
daazndood's Avatar
ORIGINAL: justasquid
ooh well what i meant was like. the brake pedal along with the brake link and other stuff i cant recognize is connected to that bracket. If i remove that bracket, i'll be yanking on the entire brake line. not sure how to disengage the rear brake first becuase i cant see behind the bracket.
Old Jan 10, 2009 | 09:10 AM
DWT74's Avatar
Make sure you blue locktite every bolt also.Dont use RED.
206cbrf2
Apr 19, 2009 11:10 AM
axsys
How-To: Mechanical
Dec 18, 2007 12:51 AM
