Need help in a hurry fuel pump problem
Old Mar 8, 2006 | 10:39 PM
Turboedsupe's Avatar
Default Need help in a hurry fuel pump problem
My bike is at my work right now with no way to get it home. I went to lunch on it with no problem then i tried to start it after that and nothing it just keeps turning over. When i hit the fuel switch the pump doesnt prime or anything. Also the left blinker light is stuck on and the blinker switch isnt pressed. I checked all fuses under the seat and there all fine. Its a 02 F4i what else can i do? I need to get it home before 8 and its already 6:40
Old Mar 8, 2006 | 10:51 PM
Tahoe SC's Avatar
Default RE: Need help in a hurry fuel pump problem
are you in gear?
Old Mar 8, 2006 | 10:56 PM
Lol no not in gear. The fuel pump would still prime even if a i was thanks though
Old Mar 9, 2006 | 01:53 AM
Alright guys the display has the left blinker staying on and the high beam light and the red light next to the left blinker is on. No matter if i switch the highs on or off the light stays on same thing with the blinker. Any ideas what can be causing this? I dont even know where to start looking
Old Mar 9, 2006 | 05:00 AM
Headlights dont turn on either but the taillights work fine. The left rear blinker is stuck on but not the front one. It sounds like a short but where would i start looking?
Old Mar 9, 2006 | 01:47 PM
slowpoke's Avatar
A short occurs when current flows directly to ground without the resistance of a load. The symptoms are usually a blown fuse, burnt wiring, or a dead battery. It sounds like you have an open, where the circuit has been interupted by something like a broken wire, a loose or corroded connector, a faulty switch, or something that breaks the loop of current.
How do you troubleshoot it? A wiring diagram for your bike is a big help, and a $5 Continuity Tester or Self-Powered Test light. Disconnect the battery, and test the components, both sides of the fuses, and all switches and relays in the broken circuit. This is the same thing a competent mechanic would do.
Doesn't your bike have a tip-over switch that shuts off the fuel pump? I would start there. Does the fuel pump and headlights have a common power wire or ground wire?
Old Mar 9, 2006 | 02:43 PM
Tahoe SC's Avatar
yo mang...someone had issues that when the headlight wasn't working, the fuel pump would not prime...but i think that's more because the bank angle sensor wires are in the same bundle and the cluster, headlight, etc.
Old Mar 9, 2006 | 03:30 PM
I already bypassed the tip over sensor to make sure that wasnt it. I need to get a wiring diagram and find that bundle of wires tahoe
Old Mar 9, 2006 | 03:39 PM
QuinC's Avatar
did you try looking in the connector there where your headlights and such are conntected its to big white connectors should be in the front of your bike on the right side. just follow your headlight wires to it if you have to. i had a problem in there where 2 of the connectors burned up with some goo crap on them and my headlights stoped working.. anyway i just had to clean it and it worked fine. that was on my 929.. i relize you dont have a 929 but it might still help. i'm sure all bikes are about the same... need spark and fuel.
this is from my 929 manual:
ENGINE DOES NOT START OR IS HARD TO START
Possible cause
Faulty fuel pump (Section 5) 1 . Check for operation of the fuel pump
Normal
2 . Inspect the fuel flow
I
Normal
3 . Inspect the fuel injector
I
Normal
4 .1 erform a spark test
Good spark
5 . Test cylinder compression
Compression normal
6. Starting following normal procedure
Engine does not start
7 . Remove and inspect spark plug
22. TROUBLESHOOTING
Abnormal
Abnormal
Abnormal
Low compression
Engine starts but stops
Wet plug
Faulty pressure regulator (~ection 5)
See section 5
Weak or no spark
• Faulty spark plug
Fouled spark plug
Faulty ECM
Broken or shorted spark plug wire
Faulty ignition switch
Faulty ignition pulse generator
Faulty engine stop switch
Loose or disconnected ignition
system wires
Valve stuck open
Worn cylinder and piston ring
Damaged cylinder head gasket
Seized valve
Improper valve timing
Improper starter valve operation
Intake pipe leaking
*Improper ignition timing (Faulty
ignition coil or ignition pulse generator)
Fuel contaminated
• Starter valve closed
*Throttle valve open
Clogged air cleaner
Old Mar 9, 2006 | 10:59 PM
Got it going the dip**** before me rigged some wires to the connector. A little soldier and its all good thanks guys
gtrude
Sep 1, 2012 12:28 PM
jmwrestler112
Sep 17, 2010 11:49 AM
tubmyster
Jul 27, 2010 10:17 AM
Jarrod
Nov 19, 2007 11:26 AM
rideitnaked
Jun 9, 2007 03:48 AM
