fuel pump problem
Old May 31, 2007 | 12:34 PM
rideitnaked's Avatar
Default fuel pump problem
i recently bought my first cane and the fuel pump was complete junk and i got to think what about an inline pump from a carb. car. the car runs ant about 4 to 7 psi. i was wondering if anyone knows the what the factory pump puts out? also if i wanted to bypass the the fuel pump relaydo i conect the the 2 plack wires but then what do i do with the yellow one?
Old Jun 9, 2007 | 03:07 AM
supernaturalbeing's Avatar
Default RE: fuel pump problem
from 1987-89 manual
Black wire is hot to fuel relay from fuse box(fuel pump)
Blue w/ black strip is hot wire to fuel pump. (does not become hot till activated by yellow w/ blue stripe wire)
Yellow w/ blue stripe wire comes from cdi box (computer or spark unit)
Make sure yellow wire doesn't touch (although it is a-12v)anything or it will confuse the cdi. From the diagram the fuel pump doesn't stay on all the time. It turns on when the cdi tells the #1 and #4 plugs to fire(same wire). Won't hurt anything though (I guess!). I'm gonna do that.
Old Jun 9, 2007 | 03:48 AM
from the book...
fuel pump flow capacity for one minute is 650cc or 21.9 oz
redirect pump to measure yours by filling up a beaker for one minute
I had already bypassed by filter, haven't messed with pump. I don't know if the yellow w/blue wire is supposed to be on/off + or - 12 volts!
gtrude
Sep 1, 2012 12:28 PM
Maddirtbiker1001
Feb 9, 2011 05:46 PM
jmwrestler112
Sep 17, 2010 11:49 AM
MPorto
Jul 7, 2009 09:19 PM
fatarse
Dec 13, 2004 09:57 PM
