Need Help With HID Install
Ok I was just looking at my set up and this is how it is suspose to be wired in. I still have to hook in the postive and negative wire to the bike wire harness unless I am still missing something. Hope this picture helps some.
[IMG]local://upfiles/13191/0D9615DE9D2F40239463440A098D6DB2.jpg[/IMG]
wayne incorrect! the 2 paddle connectors you have running into the rubber grommet does not go there!! that's the part that slides into your original wire harness for the bike, the part with the 2 sealed connects you think goto the wireharness connect to the bulb.
I've attached a crappy picture modified to give you what you need.
[IMG]local://upfiles/28355/F077E4572B4A4875AB2BB40FC16C06CF.jpg[/IMG]
those 2 paddle connectors you have just simply slide into the plug connector you removed from your bulbs. just make sure you match positive to negative or the bulbs won't turn on.
Ok thanks everyone for you help on this. I just got them installed and damn they look great. I will try to post some pictures tomorrow before it gets dark. My camera is just showing a big blurr because they are so bright and its dark now. Thanks again everyone.
