Need help balancing carbs
Old May 6, 2012 | 07:56 PM
Hootie233's Avatar
Originally Posted by IDoDirt
So, when you cleaned your carburetors, did you separate them from each other ? If so, there are springs that sit underneath the synchronization screws. If they're not installed right, then you won't be able to adjust the sync.
Ah ha! I will be sure to check this out
Old May 6, 2012 | 11:13 PM
This is what you're going to be looking for. This is one of the sync screws.
And in it's correct position.
Old May 10, 2012 | 01:24 PM
Hootie233's Avatar
Thanks DIRT! I was infact missing one of those springs but as soon as I solve one problem another pops up. After I got the carbs figured out I must have filled one of the cylinders with gas, and my starter wouldnt even crank my engine, so I pulled some plugs and started it again and everything was fine.
It idled great and rode great too. Then when I pulled into my neighborhood The bike died and would not Idle unless I physically gave it gas with the throttle. The idle adjust screw did no effect. Where should I start looking now? The bike wont start/ or idle unless I give it a bit of gas to help.
Old May 10, 2012 | 04:03 PM
Hootie233's Avatar
I can pretty much confirm that at least one of my cylinders is filling with gas again and causing the engine to bind up. Im kinda at a loss here about what to do.
Old Jan 30, 2018 | 09:36 PM
HAndHEldJEsuS's Avatar
Originally Posted by zaqwert6
Pushing on the screw will rev the bike.
I guess make sure your on the right vaccum taps for starter. One out of the 4 carbs is engine only and not actually a carb. You use that one as the base and adjust all the other carbs to that one
Yes on the f3's it's carb number 3 going from left to right
pablohoney
How To's
Jan 24, 2012 09:46 PM
spoolie25
Jan 15, 2012 08:01 PM
drzed1980
Mar 10, 2011 04:52 PM
marty095
Mar 21, 2009 10:32 AM
Mstngdrew232
Sep 8, 2007 04:09 AM
