Headlight wires
Headlight wires
hey guys, I have bought two halo projector headlight assembly's for my 07 cbr and have them wired up correctly and they are working as they should. I realized after installing and wiring them up though that the blue halo rings aren't on as standalone but with the low beam on as well with them. I am going to wire a rocker switch to the low beam headlight so I can have the blue halo rings on without the low beam on but I don't know what the two brown wires coming out of the original headlight harness are. I am not sure if one is negative and one is positive or what they are and could not find any diagrams online that tell me what they are either. If I can splice my rocker switch into the correct low beam wire, I will be able to have the rocker switch control whether my low beams are on or not. Thanks guys.
