Need help identifying wheels
Old May 15, 2017 | 04:57 PM
Ksanete's Avatar
Default Need help identifying wheels
Bought some CBR wheels for my DR-Z400 to do a supermoto conversion on.
Pictures from the seller looked much better than what i received, the wheels are pretty much trash to me, but I'd like to see if anyone can help identify what they're off of, if they're even from a CBR. Most likely will end up giving them to a friend for his CRF450X
They're both 17" 6-spoke wheels, stamped both Enkei and Honda
Imgur
Front is stamped 17xMT3.50 DOT ENKEI
Center to brake disk bolt is ~82mm on either side, 6 bolts
Imgur
Rear is stamped 17xMT4.50 DOT ENKEI
Brake disc holes are ~125mm from center to center of bolts, 4 bolt pattern
Imgur
5 bolt sprocket read ~68mm from center of bearing to center of bolt
Imgur
I've tried searching for anything else stamped on the wheel, can't quite read what this says, however.
Imgur
Any help would be appreciated, the sprocket carrier is all kinds of screwed up, the brake disc on the rear isnt even for this bike, and i guess the guy never had a disc on the front. He must've not been able to identify them either
Old May 15, 2017 | 05:05 PM
74demon's Avatar
There should be a part number somewhere on there. There is also a date code stamped in it too. It could be a dial with dots or a grid with punches in it.
Old May 16, 2017 | 01:04 AM
Ksanete's Avatar
Any idea where either of those could be stamped? It wouldnt be in the wheel dish would it? Haven't seen much else other than what's in the pictures
Old May 16, 2017 | 06:27 AM
74demon's Avatar
usually it's in a spoke, but it could be anywhere. Put up pics of each casting mark or stamped anything off of one of the wheels.
Old May 16, 2017 | 11:25 AM
CaBaRet's Avatar
They look very much like Honda cbr600 1991-92
Old May 16, 2017 | 05:32 PM
Conrice's Avatar
I'm pretty sure those are F2 rims. From some info I've gathered on the web, the 4.5 rear is right before they went to 5in wide on the F3...
From another forum
You will notice below the 91-94 has a 4.50 rear and the 95-98 has a 5.00, then 99 is 5.50.
HONDA CBR 600 F2 (91-94)
Front Rim Size: 3.50x17
Rear Rim Size: 4.50x17
Recommended Front Tire: D207, size 120/60ZR17, 36 PSI
Recommended Rear Tire: D207, size 160/60ZR17, 42 PSI
Old May 20, 2017 | 12:49 AM
Ksanete's Avatar
Certainly looks like them from pictures online. I'll see what I can do with them now that I "know" what they are
Thanks dude
Old May 20, 2017 | 03:00 PM
Ksanete's Avatar
Okay, one more question actually, how does the sprocket carrier come out? Is it pressed in? Sorry for the probably noob question, but I only know spoked wheels
Old May 20, 2017 | 04:21 PM
Conrice's Avatar
It's not even pressed in. Just give it a good tug, and it should come right out. Sometimes the cush rubbers can make it a little snug.
Old May 20, 2017 | 05:02 PM
Ksanete's Avatar
Awesome, thanks for all the help guys, appreciate it
florida f4i
Feb 25, 2009 12:42 PM
lakaiguy
Aug 24, 2008 12:38 PM
Diablo Runner
Aug 12, 2008 06:27 PM
nimblybimbly
Jun 22, 2008 11:29 PM
colhogen
Apr 15, 2007 11:37 PM
