Locating the rectifier
Old Sep 1, 2008 | 01:54 PM
cmasonrun's Avatar
Default Locating the rectifier
What fairings do i have to remove to get at the regulator/rectifier on a 2003 CBR 600RR?
Old Sep 1, 2008 | 02:04 PM
Hurricane rider's Avatar
Default RE: Locating the rectifier
I believe its either up underneath the fuel tank, or on the tail somewhere. I"m not 100% which though.
Old Sep 1, 2008 | 04:06 PM
cmasonrun's Avatar
well it wasn't on the subframe so im assuming it is under the tank...
Old Sep 1, 2008 | 10:57 PM
SalemCBR's Avatar
I thought they were all on the frame just behiend your right *** cheek.
Old Sep 1, 2008 | 11:43 PM
HAVOC's Avatar
generally the older cbrs had them on the sub frame. the newer r1's for example have them located in front of the battery under the fuel tank.
Old Sep 3, 2008 | 08:31 PM
bikehealer01's Avatar
Check in front of the battery box or under the fuel tank. The reg/rec is a finned metal box about 3 1/2 bu 4 inches square by about an inch thick with two connectors,one a three wire connection (with yellow or white wires) that connects to the stator. The other either has 2 or 3 wires one red, one black and one green. I work on so many bikes every week and havent seen a RR in the shop except for tyres in a while so i am working from memory.
knuckle
Jun 29, 2012 11:57 AM
jackassonbike
Jul 27, 2009 10:57 AM
Fortech
Jan 25, 2009 08:54 AM
DragonCBR
Mar 8, 2008 03:28 AM
cyb3rgh0st
Mar 4, 2008 08:58 AM
