Lights on with Key on?
The bike is a 01 600 f4i. I have checked all the fuses and relays and all are good. I have also checked the battery and connections, those are good. I know the there is no power going to the fuel cut off relay. I just don't know what the cause of this is. Any ideas?
sinced you checked the fuses and relays, the only other thing that I can think of that cuts power to the fuel pump is the bank angle sensor.
you can try to bypassing it. Unplug the 3 prong connector and jump the two outside prongs from the wiring harness.
However, it would be very odd for it to just quit like that.
Does your gauge cycle when you first turn on the key?
deerslider
08-24-2009 09:23 PM
