Light trouble
Old Jul 28, 2008 | 08:18 PM
Chrispy's Avatar
Default Light trouble
I can't seem to figure out the lights on my 02 F4i. The left side low beam and rear tail light work, however the high beam for that side doesn't. Now on the right side, the high beam works, but the low beam and tail light don't. Both directionals work in the front and rear. A wire diagram would be so helpful. Anyone have one?????
Old Jul 28, 2008 | 08:55 PM
justasquid's Avatar
Default RE: Light trouble
Not sure on the taillight. But I think that model only has the left side low beam and the right side high beam. Pull your lightbulbs out to check. they should be single filiment bulbs. they didnt have two low beams and two high beams. Again, I might be mistaken, But I thought that year was this way.
Old Jul 28, 2008 | 09:49 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Try posting in the F4i section ... one of those cats would know. My 04 1kRR is singles though. But if ya just hook up a nice pair of HIDs then you can run 'em both all the time for less power than a 55W low beam.
Old Jul 28, 2008 | 11:24 PM
ffingers's Avatar
Registered Users
okay, i don't know if you are kidding, but let's assume you're not...
on the f4i the left side is low beam and the right is high beam...when just low is on, only the left side is on (from behind the handlebars)...when high beams are on....both the left and right is on...as for the tail light thing, i have no idea why only one is going on...
Old Jul 30, 2008 | 03:23 PM
ZDUB's Avatar
yup 1 running at all time (left side) and then your brights are the right side (both) should be on as far as tail light you should only have 1 light in it that i remember unless you have an intergrated tail light
mikemoore
Sep 8, 2010 01:07 PM
chwelch
Aug 6, 2009 06:26 PM
slimgottabike369
May 22, 2007 09:57 AM
gadawg81
Sep 7, 2006 12:57 AM
roldaphat9
Aug 23, 2006 12:03 AM
