LED question
Old Feb 28, 2009 | 06:37 PM
Rock's Avatar
Default LED question
If I wire 4 led lights in series what size resistor would be needed?
Old Mar 2, 2009 | 02:22 PM
Lamar Vannoy's Avatar
I used google and found a calculator where you put in the specs of you led's, source voltage, and it tells you which resistor to use.
Old Mar 2, 2009 | 06:25 PM
BTBTBT's Avatar
as said above,
it would depending on the voltage source, the forward voltage drop of the LEDs and the current draw. with all of that information, you can calculate the resistance needed.
just approximately, four leds in series, probably around 200-300 ohms...
John
BT
Old Mar 3, 2009 | 01:43 AM
Rock's Avatar
Wow I didn't know they had calculators for that, I broke out the old pencil/pad and came up with 220 ohms. I just wanted someone to come up with hopefully the same numbers on their own so I knew if I was right or wrong. Thanks
Originally Posted by BTBTBT
as said above,
John
BT
Old Mar 3, 2009 | 02:23 AM
Aken's Avatar
July 2008 ROTM
http://www.oznium.com/led-resistor-calculator
Also an amazing site for tons of LED and other lighting.
Old Mar 4, 2009 | 12:01 PM
BTBTBT's Avatar
50 watt resistors? 6 ohms? ... *confused* ... why would you put LEDs in parallel (more current draw)?, 1.5ohm 130 watt resistor???? uh... you mean a LIGHT BULB ???
I'm not sure he was inquiring about load resistors to slow down his flash rate.
John
BT
Old Mar 4, 2009 | 12:58 PM
MidnightG35X's Avatar
I think people are talking about 2 different things. Rock is trying to figure out what resistor to use in series with the LED's to get the rated current (probably ~20mA) through them and Hangfire is talking about a resistor used to get the correct flash rate.
With 4 LED's (1.7V drop, 20mA current) in series, you would need a 360 Ohm, 1/4 watt resistor in series with the LED's. If the LED's have 2V drop and 20mA, you would need a 300 Ohm, 1/4 watt resistor in series. This assumes a 14V (~voltage with bike running)battery system.
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
