Laid over '00 honda cbr 600 f4
Old Apr 28, 2012 | 06:04 PM
Phillips's Avatar
Default Laid over '00 honda cbr 600 f4
Im new to ridin laid over my cbr going bout 5-10 on its left side and ever since its been sounding like something is rubbing any suggestions?? Also is the gear lever supposed to be right next to the chain?? Plz help
Old Apr 28, 2012 | 07:11 PM
nickp123's Avatar
i actually had a similar problem on my f4i. The chain was rubbing against the shift linkage but it made more of a grinding/buzzing noise and was more predominant during deceleration. I looked down at it and it seemed to be bent slightly inward so instead of trying to bend it back i just took off the rearseat and put like two washers between them and the holes they bolt up to to move it away from the chain.
If you have a rearstand put it up on there and spin the tire (with the bike in neutral) and look to see if you can tell whats rubbing. If not you can always walk the bike forward and try to look or have a buddy push the bike while you bend down and look. You get the idea....
Old Apr 28, 2012 | 11:37 PM
Phillips's Avatar
Thanx for the suggestion I tried putting on two washers n it was still rubbing but I could definitely tell that was where it was comin from cuz I could feel it on the foot peg when I rolled it any other quick fixes lol
Old Apr 29, 2012 | 03:11 AM
nickp123's Avatar
whoops rearset* rear seat is way different haha. Is it the chain rubbing against something then? If you can find out what exactlys rubbing then itll obviously be way easier to fix it
Old Apr 29, 2012 | 01:05 PM
Phillips's Avatar
Ya it's the rubber piece at the back end of the gear shifter lever
Old Apr 29, 2012 | 03:13 PM
nickp123's Avatar
yeah thats exactly what mine was rubbing against. That rubber boot/cover thing right on that like ball joint where the linkage meets? or the actual lever itself? Is your rearset or lever bent in then im assuming? It must be pretty bad if spacing it out with two washers didnt help.
Mattson
May 14, 2012 03:09 AM
joelluing
F4i - Wanted
Mar 19, 2012 01:56 PM
rpmraper
Oct 18, 2011 11:07 AM
amig
Apr 21, 2008 09:55 PM
BabeSlayer
Sep 9, 2006 04:33 AM
