jumping ign system
Old Aug 7, 2011 | 06:06 PM
coldflood's Avatar
Default jumping ign system
does anyone know how go jump the ignition system on a carbureted engine? say if ur starter system isn't working?
Old Aug 8, 2011 | 01:21 PM
stretch_the_apex's Avatar
as in the starter isnt working or your not getting spark? if the starter isnt working you could find a hill or have a strong freind push you really fast and roll/pop start it.
Old Aug 8, 2011 | 03:17 PM
coldflood's Avatar
as in I'm not getting spark
Old Aug 9, 2011 | 04:28 PM
well then theres no way to realy jump the ignition cause it still wont carry spark to the plug, have to start at one end and work to the other see what cyclinders arent sparking, pull the plugs and hit the starter button for a sec and see if they spark, then check the coils if you found some that dont spark take a plug that did spark and stick in the coil of a plug that didnt and see if it will spark. if it doesnt spark with a good plug in it then maybe the coil is bad a shop can test em for you to see if the coil is bad, if the coil isnt bad then you have to go up futher, check the line and connection to the coil use a volt meter see if your gettin power to all of em if not go up to the next connection till you find the problem.
Old Aug 9, 2011 | 04:35 PM
coldflood's Avatar
is there anyway to bypass the ign ctrl module with an earlier design what would that cost me to retrofit like contact breaker points on a transistor system or maybe even a capacitance discharge ignition system?
Old Aug 9, 2011 | 04:51 PM
sorry man thats going beyond my knowledge, i would assume that if the control module you were useing had the same fireing order as your bike it would work but just dont know.
Old Aug 9, 2011 | 05:11 PM
MadHattr059's Avatar
Strech is giving you the straight skinney. Quit trying for the easy fix. Pull each plug.
Ground them against the engine, bump the starter. See which (if any) fail
to spark. That will point to which (or both/niether) coils might be bad.
If you check the plugs for spark, you'll at least know if your assumption that
there isn't a spark is even correct. After you do that, let us know the results
and we can help you over the next curve.
Hope this helps, Ern
Old Aug 10, 2011 | 02:46 AM
coldflood's Avatar
i checked them along time ago with the heads but i just noticed some gunky looking stuff on the inside of the plug wires, what might that be? Could it be dielectric grease? How do I know? Should I clean that stuff out?
Also I have this test light from napa it told me i can test spark plugs with that I suppose you just connect the plug in series to the ground side, find a hot wire than see if it lights im not sure has anyone ever used a NAPA test light to check a plug or is it used for continuity still dunnno..
btw when i first bought the bike i have now (cbr f2) I was using a high octane (premium) would that have done anything detrimental to my plugs or whatnot?
amanc96
Sep 10, 2008 01:21 AM
Rod38um
Aug 3, 2008 09:16 PM
craigtheman
Mar 9, 2008 01:29 PM
reydelaplaya
Feb 13, 2008 08:44 PM
roldaphat9
Jul 5, 2007 09:33 AM
