temperature jumping around
Old Jul 4, 2007 | 11:41 AM
roldaphat9's Avatar
Default temperature jumping around
so I was on the freeway going about 60-65 at about 5500 rpmsand my bike normally stays at 185F to maybe 188F but it was hitting like 190-1905F and this was in the morning going to work so it was maybe 65 degrees out give or take a few degrees but it didnt seem normal to me, it kept jumping from 180 then back up then down to 185 then up again.... it even hit 200 a couple times, what could cause this? I flushed the coolant a few months ago, and checked the level last night it was full. maybe about time for a thermostat? My bikes a 01 with 27k on it.
Old Jul 4, 2007 | 12:12 PM
mikeys06cbr600rr's Avatar
Default RE: temperature jumping around
what kind of radiator fluid did you use and did this start after your flush?
Old Jul 4, 2007 | 12:35 PM
Streetdemon's Avatar
I ♥ CBRF
We had a similar discussion not long ago. Check page 6 for the post "105 degrees outside and temp".Maybe that will help. Now I know to worry when eitherthe tempreadingexceeds 230 or the engine turns red!
Old Jul 4, 2007 | 01:37 PM
roldaphat9's Avatar
read that poast allready... I know my bike, I've had it 2 yrsand I know when something is not normal, its not acting normal, I got home left my bike on, put the kick stand down, took my gloves off, got my keys out, unlocked the door, opened the garage jumped on the bike looked down and the temp gauge is at 250 flashing along with the oil and temperature lights on the speedo, never even knew that light was there....
Old Jul 5, 2007 | 09:33 AM
Tahoe SC's Avatar
try flushing again...i've had this same issue and this is where it gets funky...i've replaced every sensor and also flushed and replaced t-stat...replaced water pump, tried different fluids...while it no longer jumps around it still does ride a bit hot, but never to overheating and lights like you've said.
then about a month ago, i was just searching on the net...and i found this one dude who had the same problem with the F4i...he couldn't figure it out for about 1 year or more...so i searched his name in the forum to all of his posts...well...one came up about the solution...it all went away when he swapped out the fuel pump! WTH? i don't understand how that would make a difference...but you know what? mine started doing this jumping around thing when i took off the fuel pump to change the fuel filter...interesting isn't it?
so...when all this was going on, with the lights flashing, etc...did the coolant ever boil over? if not, then you'd want to check to see if the temp gauge is actually reading correctly. i think you may have an air bubble trapped right at the t-stat...right below it is where the temp sensor sits.
coldflood
Aug 10, 2011 02:46 AM
super60daytona
F2 Tech
Nov 17, 2010 07:54 AM
Rod38um
Aug 3, 2008 09:16 PM
daffy8daisy
May 9, 2008 10:50 AM
craigtheman
Mar 9, 2008 01:29 PM
