Jack Stand Point
Jack Stand Point
So I'm having a hell of a time here. I'm broke, so there's definitely no buying a front stand. I don't have rafters, so I can't lift the bike from there. I need to change my fork seals today, because my front end is just getting too sloppy to be comfortable with.
I need to know if I can comfortably place jack stands under this point on both sides of the bike (not sure what it is, engine mounts maybe?)
And Yes I know this engine is filthy, haven't had a chance to clean it up yet since I got it.
Are the front fork seals actually leaking? If not you could check the oil level to see if there is the correct amount in there. Or it might just need the steering head bearings adusting if that is the problem. Depends on what you mean by 'sloppy'. Loose steering head bearings will make the front end a bit vague and could be dangerous. To check (if you already know how to do this then shoot me! LOL!) grasp both fork legs and try to rock the them backwards and forwards as you face the front end. Any slackness should be easily noticeable and if there is any, it is fairly easy to adjust out. Let us know if this is the case and if you don't know how to adjust the steering head bearings? F34Me?'s advice is good by the way!
It'll be strong enough but I'd worry about slipping off. Do the lift under the very front(of the bottom of the engine). If you do it there, combined with a rear stand, you should be alright. Check the how-to section for a couple of good directions on re-building the front tubes, too.
Ern
Ern
Took another look and there's no way to get the jack stands in far enough without possible slip. Might just take it to my moms house next weekend and use her rafters. One more reason to hate apartment living.
CBRc5eric
06-21-2012 04:57 PM
riegnman
07-10-2008 09:50 AM
