Installed fan switch...
Don't forget to turn it off or you'll drain the battery. Might be better behind
a relay to the tail-light or something to "switch" it off with the ignition.
+1 on IDoDirt's comments, as well. He's the man, and his advise should always
be carefully considered.
Ern
Ern
The switch is a good idea so you have total control of when/how long you have the fan running, but I would wire it through the ignition ON circuit and add the in-line fuse. It would be so easy to forget to turn the switch OFF and you'd come back to a 'flat' battery. I hadn't used my bike for a while and went into town with my headlight on (5 miles away) and when I came back the bike wouldn't start! Fortunately, my grandson helped me out by fetching my 'jump start' machine and I was on the way in no time. You might not be so lucky! I fitted a switch to an old Skoda car years ago and it got me out of trouble until I was able to buy an new radiator switch. I left the wires and switch in place so I could use this system again for insurance against another switch in the radiator going bust!
