If u like a challenge try to figure this out.
Old Jul 21, 2008 | 10:30 AM
laxmsoe's Avatar
Default If u like a challenge try to figure this out.
I have a 1996 CBR 600 F3. The bike used to run great had absolutly no problems with the bike until one day i was riding the bike and i decided to pop a wheelie. everything was going good until the front wheel hit the ground and then everything seemed to go dead. It is almost as if there isnt a battery in the bike even though there is a new one in there. I have riped this bike appart there arnt any skins or anythign left on it. I have checked teh fuses and they all work. When i turn the key there is no light or sound but when i check with the volatage meter i get power to the CDI box and teh voltage regulator. So if u could please help asap this is my everyday ride so i hope to get it back on the road quickly thanks
Old Jul 21, 2008 | 10:55 AM
Northernfirepower's Avatar
Default RE: If u like a challenge try to figure this out.
Check the wires under the gauge cluster by all the bulkhead connectors. Mine looked 1ike the large ignition wire wore thru and grounded out. That would sound like what you have going on.
Old Jul 21, 2008 | 12:11 PM
rider0033's Avatar
check the 30amp main fuse at the start relay
Old Jul 21, 2008 | 03:04 PM
chainstretcher's Avatar
Admin Emeritus & MVN
And next time only post the question up once ... I know, the forum prolly ate the first one[8D]
Old Jul 22, 2008 | 03:01 AM
CBR_600_Rider83's Avatar
I would check the main ground bolt back out or eye let is not making a conection. Good Luck
Old Jul 22, 2008 | 06:43 AM
laxmsoe's Avatar
Where would i look to find the main ground bolt????
Old Jul 22, 2008 | 10:31 AM
Trace the neg battery terminal I think. Also, that should have been my first answer. Be sure your battery connections are good, clean, and tight. That happened on my quad, and all it was was the neg cable end came loose making a bad connection.
frozenpoet
Aug 31, 2011 10:25 PM
Steel Horse Rider
The Hurricane Saloon
16
May 5, 2011 07:48 PM
kowen1208
May 27, 2010 10:22 PM
Rod38um
Sep 18, 2008 05:44 PM
Jmill83
Apr 14, 2006 02:04 AM
