IDENTIFY THIS PART..
Old Aug 31, 2007 | 03:05 AM
Built B16a's Avatar
Default IDENTIFY THIS PART..
im having a FI problem, i can't get my fuel pump to prime, and when i run the fuel pump hot, i still don't get ignition...
i was tugging at the wires near the injectors, and i think i came down to the conclusion that this is my problem. can anyone identify it or have any idea's as far as testing it?
thanks.
Old Aug 31, 2007 | 03:12 AM
HAVOC's Avatar
Default RE: IDENTIFY THIS PART..
i believe that to be your valve assembly on your air injection system
part # 10
VALVE ASSY.
36450-MEE-000
Old Aug 31, 2007 | 03:30 AM
Built B16a's Avatar
alright, yeah, i doubt thats my FI problem... i dunno what to do.
my headlights went out, and i traced the problem back to the starter button, a soilder came loose, and i repaired, and tested the switch and its all good now... i get all my lights, and everything, but all i get is the FI light now.. sometimes the fuel pump primes but, not 100%. i also bypassed the bank angle.
what feeds the fuel cut off relay? and where does it go? thats where i need to look.
the dash says neutral, so im assuming thats good.. the kickstand shouldn't be a problem untill i get into 1st gear.
damn, im soo ready to just take this into the shop... damnit!
Old Aug 31, 2007 | 03:37 AM
HAVOC's Avatar
why did you by pass the bank angle sensor ? when turning my bike around on the kickstand my fuel pump would somtimes stop working then i would sit on it (balanicng the bike in a normal riding position) and then shut the bike off and try it again and the fuel pump would prime this time... so im guessing that you could have a problem with the BAS ... and yes make sure you're in neutral and the kill switch is in the off (deactivated .. meaning bike will run) position and hook the bas up normally and see what happens... also what happens when you send power directly (jumping) directly to the power and by pass the relay ?
Old Aug 31, 2007 | 03:44 AM
Built B16a's Avatar
well, origonaly i thought i had a probelm with teh BAS... and i atually hacked it up, learning how the sensor worked.. it was a oil submerged sensor using magnets for connection.. anyways, i wanted to bypass it to eliminate that error for good. other than dropping the bike, and it still running, what harm does jumping the BAS have?
right now the BAS is bypassed, and the bike is on a stand.. so its as level as it can be.. still intermitant starts.
the bike has been in neutral for the past 3 days.. [sm=badbadbad.gif]
and what do you mean have the stop switch in the off position?
"and yes make sure you're in neutral and the kill switch is in the off (deactivated .. meaning bike will run)" that doesn't make sence.. the off... means oposite of RUN?
ive tested the relay numorus times.. i get great continuity.. but im unsure of what wires to "jump" to basicly bypass the fuel shut off relay.
Old Aug 31, 2007 | 03:54 AM
Built B16a's Avatar
ok, now the PDF repair file for the F4i.. it says the brown solid color goes to the fuel pump...
key on, neutral, kickstand down.. in RUN.. with the pump jumped, and running.. i crank, but no start.
the other half of that relay, is blk/wht... its also spliced into the engine shut off relay, and its ground.
i don't know if i have a bad ground somwehre, or a bad sensor.. damnit, this is soo ****ing difficult.
Old Aug 31, 2007 | 05:43 AM
Ludefreak's Avatar
take it to a dealer..
Old Sep 2, 2007 | 05:33 PM
Built B16a's Avatar
$90 shop rate
MadisonD
Aug 2, 2010 06:52 PM
Speedemon636
Mar 3, 2009 09:36 PM
99camarosupersport
Apr 17, 2008 08:14 PM
Turbinator
Mar 8, 2007 05:42 PM
Jaybird180
Jan 2, 2007 04:05 PM
