I accidently shorted the battery
Old Nov 15, 2010 | 03:23 PM
Gotpepsi's Avatar
Default I accidently shorted the battery
Oops.. i knew this was going to happen, in my head i was thinking something was going to go wrong lol. Anyways because i was being lazy, i tried putting a battery charger on my bike, But i had to squeeze the (+) side between my tank, and a metal bracket. The battery charger was plugged into the wall and i touched the positive side to the battery, and it made a big blue spark. lol lazyness kills, so i just decided put my charger away.. anyways the bike started and ran fine, i thought it would blow a fuse. should i check any fuses to make sure they didnt blow?
Old Nov 15, 2010 | 03:52 PM
Piranha's Avatar
No, you would not have to check the fuses. Electricity follows path of least resistance....so that big blue spark you seen... basically went from the (-) negative terminal to the (+) positive terminal. Its not good for your battery itself ... but it didnt hurt the rest of your bike electrically. The spark itself may leave a burnt spot on the metal where it jumped though. .. .
Old Nov 15, 2010 | 03:55 PM
Gotpepsi's Avatar
so i guess there is nothing to worry about except for a burnt spot on the metal?
Old Nov 15, 2010 | 04:24 PM
LJ Harp's Avatar
Official CBRF Decal Man
yep you should be good my friend
Old Nov 16, 2010 | 07:17 AM
brveagle's Avatar
For grins, throw a voltmeter on your bike while it is running and make sure it is still charging.
I have seen instances like this taking out the R/R...
Old Nov 16, 2010 | 04:47 PM
kilgoretrout's Avatar
Administrator - Retired
Yeah, I'd probably check charging voltage just for the heck of it, too. You're probably 100% fine, tho, especially with the bike off.
I know I arc welded my intake to the hood of my car once with battery voltage.
That chit killed the car completely and screwed some stuff up. Even fried the distributor cap and rotor somehow.
91-CBR600-F2
F2 Tech
Apr 29, 2013 03:23 AM
live4liftin
Apr 14, 2011 07:19 AM
Gotpepsi
Oct 24, 2010 03:49 PM
Robles929
May 18, 2009 11:50 PM
jahnaboi
Mar 31, 2008 11:04 PM
