Hurricane.. electrical problem
Old Jun 4, 2011 | 09:15 PM
hard2obtain's Avatar
Default Hurricane.. electrical problem
My 1990 hurricane starts to burn the starter relay 30A fuse. I start the bike but around 7 seconds later the fuse blows.
what can be? Rectifier?
Old Jun 4, 2011 | 10:37 PM
STJ2011's Avatar
r/rcould be on of the possibilities. the r/r is the charging system. if the battery is charged then you can start the bike with the r/r disconnected. to do this there is a power cable should be red with a white tracer. disconnect that, try again.
if problem persists r/r is not the problem.
a short in the system, has anything been rewired recently?
Old Jun 5, 2011 | 07:44 PM
Ok, today discover 2 things
1.- I have a false contact in the Rectifier plug. That is an easy fix.
2.- Voltage on battery goes up when i rev the bike. It rev around 3K and voltage goes around 19 volts, probbably more if i rev it higher, so i rappidly decide to turn of the bike.
I suppose that voltage increment is not normal. I think the job of the rectifier is to mantain an stable voltage at any RPM, but i don´t know if im correct.
Old Jun 9, 2011 | 12:42 AM
Any?
Old Jun 9, 2011 | 06:07 PM
Yes, you are correct that the voltage should not exceed about 15vdc. The voltage does fluctuate but should stabilize above around 3000-5000 RPM.
Old Jun 10, 2011 | 01:44 PM
Ok, then im going to try changing the Voltage Regulator
Old Jun 18, 2011 | 09:12 PM
Voltage regulator changed.... but still have the same problem, at idle got around 14.8 volts and if i throttle the voltage goes up...
What else need to check???
kwood
Jun 1, 2020 09:53 AM
paulwarrendublin
Jul 19, 2013 12:10 PM
letsride
Jul 29, 2009 09:49 AM
patso
May 5, 2009 10:48 AM
Xuracing
Jul 3, 2008 01:15 PM
