howling noise
Old Jan 9, 2011 | 05:40 PM
midnite's Avatar
Default howling noise
ok just wondering,,i was on the highway today with my f2 and when i took and off ramp and came to stop light i noticed that my bike was makeing a howling noise for a few seconds but then it went away. just wanted to see if anyone els has ever heard of this and if so what could it be?
Old Jan 9, 2011 | 05:41 PM
midnite's Avatar
it kinda sounded like a belt slipping or somthing..
Old Jan 9, 2011 | 05:42 PM
midnite's Avatar
or maybe a vacume leak but other then that the bike runs great
Old Jan 9, 2011 | 09:15 PM
justasquid's Avatar
What was the road surface like? If the surface was rough, like with a tar and chip road, it can be quite noisy while your moving.
if it was while you were stopped, its hard to say. can you describe the noise a little bit better. Did the bike vibrate at all while it was making the sound?
Also, don't forget about sounds around you. If you just came from a freeway, its possible the noise was not even your bike, but with a helmet on, it can be hard to tell sometimes.
Old Jan 10, 2011 | 08:28 AM
midnite's Avatar
It has never leaked anything in the past I checked the cap it's on there good and dry. It didn't vibrate at all when it did it. It was just when I came to a stope I heard it howl likea high pitch wine. But only for a few seconds then it went away. It's never done it before. Perhaps the cct maybe. I couldn't get it to do it again.
Old Jan 11, 2011 | 02:59 AM
Shadow's Avatar
I'd check two things
1 Your chain is lubed
2 Your wheel bearings are all good................
I've had that noise from both areas on bikes in the past, so check them to be safe - hate to see you lose a wheelbearing miles from any help !
Old Jan 11, 2011 | 10:46 AM
adrenalnjunky's Avatar
+1 on the "might not have been your bike at all" idea.
Leaving work the other day - I'm waiting to pull out into traffic, when I start hearing a metallic knocking. It happened just as I increased revs to roll forward in the line of cars and went away. I pull forward again and it happens again. Now I'm kinda worried something uncool is happening in the engine.
I let out again and I'm next in line to pull out. I hear the knocking now, getting louder, but now without my revs increasing.
then I look up and notice the bucket truck in a parking lot right across the street raising its lift to change a lightbulb on a lightpole. sure enough - now that I'm looking at it, I can tell it is making a weird ratcheting clanking that is what I swore was coming from underneath me.
Helmets redirect sounds in the weirdest ways.
still required a 2nd gear rip up the block for peace of mind :-)
new06f4iowner
Sep 17, 2011 11:27 AM
blind_skater26
Jun 7, 2010 11:43 AM
zack2746
Aug 17, 2008 09:12 PM
vdubsales
Aug 3, 2006 03:49 PM
specsprint03
Sep 19, 2005 04:28 AM
