how to make PCIII maps
RE: how to make PCIII maps
I'm assuming you have the software that came with the PCIII. It has a manual for using it under the help menu.Basically you could just open a pre-made map and edit it by changing the values (this would at least give you a starting point). Each number in the grid correspondes to the percentage of injector duty cycle for that given throttle position at the corresponding RPM.
With that said, I don't think it would be a good idea for you to just createa map with out being able veiw air/fuel data. It would be best to see if someone on the forum has the same setup and has already had their ride tuned at an authorized dealer. Then you could just download and install their map or you could pay to get your bike tuned. Plugging in your own numbers could result in running rich or lean. In any case, you wouldn't reap the benefits of having the PCIII since the engine wouldn't be running efficiently. Just my opinion but if you'd like to try it on your own the software manul that came with the PCIII has all the answers your looking for.
