Help!! Transmission Wont shift what did I do
Old Mar 8, 2013 | 07:55 PM
Pokster's Avatar
Default Help!! Transmission Wont shift what did I do
Ok tried to get my 94 Honda CB 1000 started and well the battery was dead so I pop started it got it going but then it would not shift at all. Played around with the shifter and got it to shift then took it about 50 feet and then it would not shift again and unable to get it in gear even beating it sounds like it is stuck between gears.
So what did I do to it and any idea how to fit it?
Old Mar 8, 2013 | 11:01 PM
Check to make sure that the shifter and linkage has not come loose or is binding.
Old Mar 9, 2013 | 07:09 AM
Pokster's Avatar
Thanks I look at today to see what the linkage is doing as I never thought to look at that.
Old Mar 9, 2013 | 07:19 AM
Pokster's Avatar
Ok just looked at the diagram for the linkage and have to ask how do I check that?
Old Mar 9, 2013 | 07:51 AM
Conrice's Avatar
isn't it just a pinch bolt onto the shift rod?
i can't believe anything changed to the drum or anything while it was sitting still (no matter how long it sat)....
it feels like it's stuck right? as in, you can't move the shifter at all? or, are you able to move the shifter freely and it won't find another gear
Old Mar 9, 2013 | 08:25 AM
Pokster's Avatar
yup it is stuck cant move the shifter up or down. It locked up after I pop started it before that it shifted fine while in the driveway.
Thomas Hughes
Aug 4, 2015 12:00 PM
hillbilly86
Jul 15, 2013 11:50 PM
greddy_1700
Aug 27, 2010 02:02 AM
anomalyapparent
Aug 22, 2008 07:09 PM
nstyle73
Dec 13, 2007 06:15 PM
