Help. Something is connected to the positive terminal on battery
Old Jun 13, 2009 | 05:29 AM
Ussrdolphin's Avatar
Registered Users
Default Help. Something is connected to the positive terminal on battery
As well as my main connector there is a black plastic tube connected. It screws apart in to two parts and inside is a glass 10A fuse. It was casuing me problems starting - as in needed to shove it to get ignition lights on and then caused total electric cut out when I wis riding the bike.
If I disconnect it everything seems fine - is it safe to do this. Thanks in advance.
Old Jun 13, 2009 | 10:30 PM
pacemaker's Avatar
My guess is that someone had but in another fuse able link for get power to something else (positive lead to the battery & earthed at the source) & if it's no longer connected, then where ever that wire leads to is shorting out.
Old Jun 16, 2009 | 03:53 PM
johnnyx's Avatar
+1. NOTHING stock runs a separate lead to the battery, so it's something aftermarket. What aftermarket mods do you have that require power?
Old Jun 16, 2009 | 06:56 PM
jfizz84's Avatar
does it run to a toggle switch. maybe the internal fan doesnt work anymore so someone hookep up a diff fan and powered str8 off the batt like i did
Wheelie2
Dec 27, 2013 05:03 PM
K7inne09
Oct 7, 2010 01:08 AM
corps~racer
Sep 11, 2009 04:21 PM
Ussrdolphin
Jun 14, 2009 01:29 AM
mauthman
May 15, 2008 12:11 AM
