Help with slipon install
Old May 30, 2005 | 10:22 PM
FBlade's Avatar
Default Help with slipon install
Need some help here. I'm installing a two brothers slip on system and am stuck at the point where you have to disconnect the power valve cables from the valve and the servo. Can anyone give any pointers? Also after its off and the new system is on will not having it cause any problems? Thanks in advance for the help!
FBlade
FBlade's Avatar
Default RE: Help with slipon install
ORIGINAL: FBlade
FBlade
PS: Its on a 1000rr
Old May 30, 2005 | 10:26 PM
chainstretcher's Avatar
Admin Emeritus & MVN
There's a cap where the cables go to the flapper on the exhaust. Take this off (2 screws I think) and loosen up all the jam nuts that keep tension on the cables. Remove the cables from the exhaust end -- it's basically getting enough slack to get the barrels outta the holes.
Now look on the left side of the bike right behind the idle adjust **** -- the round thing hanging down is the servo. You should have enough slack to remove one side. Then just turn the servo so the other side is visible and remove the second cable. Easy as pie.
Old May 30, 2005 | 10:29 PM
FBlade's Avatar
That's awesome!! Thanks for the quick reply!
Old May 31, 2005 | 10:12 PM
FBlade's Avatar
It's on! One more question....the directions said nothing about where to put the liquid gasket. Is it needed? If so where. It seems that everything is tight.
Old May 31, 2005 | 11:17 PM
My 2Bros didn't have a gasket -- flanges were snugged together and no worries.
yellowjacket06
Mar 7, 2014 08:30 PM
Saltcreep
Apr 11, 2012 05:27 PM
CBRrider01
Aug 6, 2008 10:49 AM
TheFactor
Jul 8, 2008 10:19 PM
iroc_dis
Mar 19, 2007 03:52 PM
