HELP -- Oil Drain plug
Old May 10, 2007 | 07:05 PM
bufferedaspirin's Avatar
Default HELP -- Oil Drain plug
I was changing my oil and had just drained all of the oil out of the bike. I was going to put the oil drain bolt back on, along with a new aluminum waser. So, I set my torque wrench to the proper spec (21 ft-lbs) and started torquing it. But for some reason, my torque wrench never clicked and I stripped the bolt!!
I went and bought a new bolt, and now it looks like the threads where the bolt screws into are stripped, too!!! I'm such an idiot, please, what can I do about this?
02 F4i
Old May 10, 2007 | 07:09 PM
therabbit's Avatar
Default RE: HELP -- Oil Drain plug
How stripped is it? can you run a tap through it and even it out? or are the threads completely gone?
Old May 10, 2007 | 07:17 PM
chpsk8er630's Avatar
Youwill either have to drill and retap to a bigger size drain plug or helicoil it. A helicoil will be alot stronger since it is a steel indert. If u dont know what u are doin have a dealer do it. It shouldnt cost that much.
Old May 10, 2007 | 08:09 PM
How do I know? Do I just stick my head under there and look, or what?
Could a Heli-Coil leak?
dachamp312
Mar 15, 2011 11:32 AM
94_F2_KING
Aug 23, 2009 12:19 PM
t3gr4
May 20, 2009 07:28 PM
dwarfdwarf
Jun 11, 2008 10:52 PM
tinter
Jun 28, 2005 01:11 AM
