drain plug
Old Jun 11, 2008 | 12:34 PM
dwarfdwarf's Avatar
Default drain plug
Where is it?
Old Jun 11, 2008 | 12:50 PM
Default RE: drain plug
For the Oil ? It's right on the bottom of the engine. Kind of the rear center of the oil pan. Fairly large bolt if I recall correctly.
Old Jun 11, 2008 | 01:40 PM
Dave71's Avatar
Done a full oil change today, 17mm nut underneath..
Old Jun 11, 2008 | 02:20 PM
dwarfdwarf's Avatar
im sorry. i meaant for the coolant
Old Jun 11, 2008 | 02:30 PM
Shadow's Avatar
I've not found one - pull off the bottom rad hose I think.......
Old Jun 11, 2008 | 03:24 PM
mr303's Avatar
Its on the water pump, you have to remove the left hand fairing to get to it.
Old Jun 11, 2008 | 03:50 PM
dwarfdwarf's Avatar
what bolt is it mr303? thanks
Old Jun 11, 2008 | 04:07 PM
mr303's Avatar
According to the manual there are 3 mounting bolts and 1 drain bolt, the 3 mounting bolts attach around the flange of the pump and there is 1 bolt that is on a raised area of the pump, crack that open and see what happens. I was considering changing the fluid in mine and had a quick look with the fairings off, I did not undo the bolt to see if it did drain. If it does not drain from that bolt you could just loosen all the flange bolts and let it drain out that way.
Old Jun 11, 2008 | 04:17 PM
pacojoseph's Avatar
from Haynes
[IMG]local://upfiles/16639/8A2F3FD655B542A38E3AF7522A851387.jpg[/IMG]
Old Jun 11, 2008 | 08:46 PM
malbojah's Avatar
Look for the one that has the crush washer on it.
