Help for cbr300 starting problem
Old Sep 1, 2023 | 09:24 PM
Cbrnoob88's Avatar
Default Help for cbr300 starting problem
Hi folks am very new to bikes. Had left unattended for a couple of weeks so normally start often if I'm not riding. But I went to start and it wouldn't. Bump started no worries. But intially thought it was a flat battery or buggered battery. Thought weird cause I haven't even done 300kms on it.
To my suprise after charging it still did not start. I just get a constant ticking noise (or the wah noise when you first turn it on and the light comes on)coming from the relays and am unsure what relays they are. Help for a new person pleeeeease as the weather here is beautiful!!
Old Sep 2, 2023 | 12:38 AM
dannoxyz's Avatar
Could be dead battery beyond repair with charging. Do following tests:
1. battery voltage with everything OFF, volts = ??
2. battery voltage with key ON, start/stop = RUN, volts = ??
3. battery voltage while pushing START button, volts = ? ?
Old Sep 2, 2023 | 01:55 AM
Cbrnoob88's Avatar
I don't have anything to test it with
Old Sep 2, 2023 | 08:39 AM
rockpool's Avatar
If you are telling us that it will bump start fine, but when you hit the start button it just clicks, then there's a problem with the battery.
Use a PROPER battery charger to charge it up (not a trickle charger) and report back.
If you can't do that - take it to a mechanic.
Old Sep 2, 2023 | 01:08 PM
dannoxyz's Avatar
get this: https://www.harborfreight.com/7-func...ter-63759.html
learn to use it: https://learn.sparkfun.com/tutorials...e-a-multimeter
Doing your own diagnostics and repairs will save you ten$ of thou$and$ in repair bills.
Old Sep 2, 2023 | 02:22 PM
Cbrnoob88's Avatar
What do you consider "proper"?
Old Sep 3, 2023 | 12:22 AM
dannoxyz's Avatar
You want smart multi-stage charger. These usually have an initial desulfating stage to recover deeply discharge batteries. Also long-term storage mode where it only charges to 95%. Then lets battery sit and self-discharge to 85% or so. Then pulse-charges it back up to 95%. Much, much better for battery-life than trickle/tender chargers that max-out battery at 100% all the time. Fry it for sure!
https://bikerrated.com/gear/maintena...tery-chargers/
https://www.topmoto.com/best-motorcy...argers-review/
https://products.motorcyclenews.com/...tery-chargers/
Amazon Amazon
<--- good charger
Old Sep 3, 2023 | 07:54 AM
rockpool's Avatar
What Danny said - multistage. I particularly like the noco Genius range.
If you have a car as well, buy a car-sized charger with at least 5A capacity - it will work just as well on your bike.
Spamola0
Apr 28, 2020 03:21 PM
michaelsbt
Feb 18, 2009 01:39 AM
94cbr600kid
Dec 19, 2008 09:18 PM
F4iMane
Sep 5, 2008 10:08 AM
Knieghtz
Jan 22, 2007 09:38 PM
