Help with camshafts timing!!
Old Jun 24, 2020 | 11:06 PM
Joe Halzel's Avatar
Default Help with camshafts timing!!
ok so I have a 92 honda cbr 600 f2 and I had to replace the head and im having problems. My pulse generator has no timing marks. So if I don't have timing marks how do I set the timing when putting in the camshafts? I assume that i need to put the motor at tdc and then put the shafts in as described in the manual? And to put the motor at tdc how many rotations do I have to turn the motor? Ive heard it needs to be on a compression rotation or something? I thought I had it at tdc and after installing the cams I started up the bike and she fired right up but after running for a while it stopped. I took the carbs off and looked in the intake and I broke a valve on the #3 cylinder. Did I not have it at tdc and a piston broke it or just a bad valve?? Im putting in new valves and I need help
94CBR
Sep 20, 2012 02:34 PM
phack
F2 Tech
Jun 9, 2012 11:38 PM
Jfisher7
Jul 15, 2009 11:36 PM
MobileMidget
May 6, 2009 01:36 AM
mattf
Jul 9, 2008 11:33 PM
