Help - timing
Old Jun 9, 2012 | 09:25 PM
phack's Avatar
New Member
Default Help - timing
how to time my bike. just replaced cams, now what 94 f2 600 cbr. just need timing mark help please and where to center what piston. will be working on it today. help
Old Jun 9, 2012 | 11:38 PM
JankCibberf2's Avatar
Sure it's simple. Intake cam has a dash that says in with a _ underneath. Line that up parallel with the head. Then on the exhaust cam it says ex with a _ underneath. Line that up on the right parallel with the head. Before doing all that, turn the motor to tdc by pulling the ignition pulse cover with a 17mm and turn the motor clockwise with a 14mm until the I that's inbetween the t and : with the dash that is at the 1 o'clock position near the threaded area of the ignition cover. If you can't figure it out by that look up the manual or search it
StrongPerf
Jan 2, 2010 04:37 PM
weekendrider
Feb 3, 2008 03:58 AM
allenpa5
Aug 16, 2007 02:59 AM
BiziB
Nov 4, 2006 11:54 PM
one2gofast
Jul 19, 2006 02:46 AM
