headlight issue
Old Jun 15, 2011 | 04:27 PM
itsme71190's Avatar
Default headlight issue
went riding and headlights cut out. highs dont work. my fuse is good. and i checked the connections real quick and all look fine. my audi strips work as do blinkers, gauges, and tail light.
Old Jun 15, 2011 | 09:23 PM
pacemaker's Avatar
oops posted twice
Old Jun 15, 2011 | 09:24 PM
pacemaker's Avatar
Is it both filaments? as in no lights at all? Then most likely the bulb is cactus. If just your high beam not working then probably a blown high beam filament, (so low beam will still work). Either way your most likely up for new bulb.
Also make sure the connectors are not corroded & have good contact.
Old Jun 15, 2011 | 09:27 PM
toptaz1000rr's Avatar
or you have too much added and you need a resistor or relay to balence out the power asked for by the bike
Old Jun 16, 2011 | 12:52 PM
itsme71190's Avatar
I had the halo on since last season. Neither lights work. I'll disconnect the connectors n reconnect em. Then try the bulbs.
Old Jun 16, 2011 | 12:53 PM
itsme71190's Avatar
What do u mean by bulb is cactus?
Old Jun 18, 2011 | 08:40 PM
itsme71190's Avatar
bump...
skullrider
Apr 13, 2020 01:48 PM
AggieLawyer
Sep 17, 2009 10:37 AM
2005RX8
Sep 28, 2008 10:52 AM
vietladin
Jan 14, 2008 11:57 PM
cafrin100
Apr 30, 2007 01:05 PM
