Headlight Dont work
I have a 96 cbr 600 f3 my headlight dosent work I have checked the bulb and the fuse are both good I have no power at that the switch or at the bulb. The fuse that i checked is at the right side of the bike is there any other place to check for fuses and or relay?
Any suggestions would be a huge help.
download your shop manual and find where the fuse is. Click here right click on the "click here to play video" and you will see that you are actually downloading the zip file with the pdf document.
I had this problem with a bike once..it was the "start" button was gummed up and sticking ( not releasing)
Most bikes will kill the headlight when it is being started to minimize the load on the battery, try wiggling the "start" button or the key ( ignition could be worn as well, had that happen before also)
Hope that helps..
Hope that helps..
