Headlight Dont work
Old Dec 1, 2005 | 05:40 PM
Ride till I Die's Avatar
Default Headlight Dont work
I have a 96 cbr 600 f3 my headlight dosent work I have checked the bulb and the fuse are both good I have no power at that the switch or at the bulb. The fuse that i checked is at the right side of the bike is there any other place to check for fuses and or relay?
Any suggestions would be a huge help.
Old Dec 2, 2005 | 12:58 AM
doncollins's Avatar
Retired Administrator
Default RE: Headlight Dont work
download your shop manual and find where the fuse is. Click here right click on the "click here to play video" and you will see that you are actually downloading the zip file with the pdf document.
Old Dec 2, 2005 | 01:06 AM
sirlimpzalot's Avatar
I had this problem with a bike once..it was the "start" button was gummed up and sticking ( not releasing)
Most bikes will kill the headlight when it is being started to minimize the load on the battery, try wiggling the "start" button or the key ( ignition could be worn as well, had that happen before also)
Hope that helps..
Old Dec 2, 2005 | 01:51 AM
Thanks for the advice I will try those things over the weekend I wish I had time to look at it tommorow but I have to work a 12 hour shift on friday
p.s. Thanks again
Ironhead
Sep 20, 2014 04:47 PM
wagonwhatmp5
May 7, 2012 04:39 AM
alysiak00
Sep 25, 2010 02:26 PM
chpanther69
May 10, 2007 07:29 PM
01929RR
Sep 26, 2006 03:16 PM
