Gunfighter (front headlight) Help
Old Mar 26, 2006 | 11:10 AM
jxc574's Avatar
Default Gunfighter (front headlight) Help
How do you Remove the stock headlights from an F4i and still be able to run it? Becuase if you remove the stock headlights you cant run it? Do you just get a connector and make it look like its(headead lights) there...please help
Old Mar 26, 2006 | 12:11 PM
thunder31634's Avatar
Default RE: Gunfighter (front headlight) Help
its not the headlights that need to be hooked up, its the bank angle sensor, its in the same harness and bolted to the back of the headlight assembly, you can either relocate the sensor or bypass it by connecting the white/black stripe and the red/white stripe wires together
Old Mar 26, 2006 | 12:25 PM
jxc574's Avatar
Do i have to buy the whole head light assembly becuase the harness is directly connected...or is wiring harness seperate.
ps doin f4i...conversion to my f4
ranchome
CBR1000F Wanted / Swap
16
Mar 20, 2012 06:51 PM
Hudson91
Jul 27, 2010 07:02 AM
Harry_T_Hamster
Mar 28, 2009 12:26 PM
cyber00677
Aug 3, 2007 03:57 PM
