Gas Tank removal / fuel line disconnect
When removing the gas tank on a '06 F4i, do you have to either drain the tank or run it out of gas when you disconnect the fuel line in order to keep gas from flowing out?
I had not done this before. Or, if I did, there was a petcock to turn off, as I recall. There isn't a fuel petcock on a fuel injected motor.
I did lift the tank and manage to change out the air filter with my two daughters holding it up and the fuel line connected. One of them got some leaking gas. I didn't have a siphon or the desire to siphon out all the gas. The tank was full.
Also, how do you unplug / disconnect the fuel line from the tank? WIll the gasoline just rush out when you do that?
I can't even find a YouTube video on this.
Just got a like new yellow '06 F4I this weekend.
Leave the lines on the tank. Undo the nut on the fuel rail and remove the seal and line. Have a rag handy for a little gas to spill. For the return line, either clamp the line with a vice grip before disconnecting it, or pinch it with a pliers and remove it from the rail and plug it with a bolt.
The fuel rail is on the motor with the injectors.
The pressure line has a banjo fitting on it. It's on the right side of the motor by the frame. The return hose is on the left side by the FPR and is just clamped tight. Both go to the bottom of the tank.
The other hoses on the tank are drain tubes and don't have fuel in them.
Both hoses poured out fuel when I disconnected my tank. It was quite uncomfortable holding a fuel jug up to the side of the bike letting the full tank of gas pour out the fuel lines into the jug while also holding up the fuel tank. Made quite a smelly mess in the process too.
That brings up another question, what are the three hoses going into the fuel tank and what happens if one of them gets pinched when putting the tank back on? On another bike on mine, a Bandit, I'm getting a kind of hesitation or jerking when I accelerate rapidly ever since I removed the tank to put in a clean air filter. Could one of the hoses gotten pinched and cause that?
If one of the fuel lines is pinched, then sure it can. If it was fine before but not now, then it must be something that was changed by whatever you did.
cc rider
Jun 18, 2016 10:24 AM
comodidit
Mar 25, 2011 12:31 PM
