Gas tank lock problem
Old Jan 18, 2013 | 03:03 AM
viGeflafed's Avatar
New Member
Default Gas tank lock problem
i have my honda cbr 500 and my key hole for my gas cap corroded and froze the lock and now i can't open my gas tank to put gas in. If anybody knows about the best locksmith who can solve this issue plzz inform about it
Old Jan 18, 2013 | 10:05 AM
CorruptFile's Avatar
June 2013 ROTM
If it is corroded, you can try hitting it with some pb blaster or some other spray lubricant to loosen it up. A locksmiths picks won't do it if your key won't.
If you can't loosen it up, you might need to drill out the barrel, then you need a new cap.
And if you want a suggestion on who to use as a locksmith, your location would help :P Maybe you will get lucky and get seen by someone close to you.
Old Jan 18, 2013 | 12:39 PM
74demon's Avatar
I don't know of a locksmith in India...
Old Jan 23, 2013 | 12:06 AM
Missynet's Avatar
How did you solve the problem?
Got the same issue :/ Have used some w40 spray but that doesnt seem to help... dunno even how mutch ans so on to use it.. sprayed that in around 3 times over 4 hours... notin..
Old Jan 23, 2013 | 12:10 AM
June 2013 ROTM
WD40 isn't a great penetrating oil. Get some PB Blaster.
Old Jan 23, 2013 | 12:14 AM
Missynet's Avatar
Mnjaa I not very sure we have that on sale here... Will look into it tough, cheers!
Old Jan 29, 2013 | 02:56 AM
Missynet's Avatar
After over pouring it with oil, two days i added a little food oil after every three hours, then got Wd-40 oil for one day. Still nothing. Then I started complaining about it to every guy in my company who I knew knows something about cars/technical parts (after i found out that pb plaster is not available here and the one people here use instead that is compared to water). And after my hopeless try-outs comes one guy looks at it. does the same thing that I did to get the lock open and I turn my back on him for just under a minute and he has got it open
I just stared there
I had no words, Bet I loosened it up for him
I took it home and seems that the locks didnt function properly. So I took my lock opening kit and played around with it a bit, added lil oil and now seems to work without problems.
Happy me
Old Feb 26, 2013 | 05:49 PM
mnguyen84's Avatar
good to hear it worked out. In the past when the lock on my fuel tank got stuck, I sprayed some carb cleaner into it and use the key to wiggle it around a bit. Now and then, i give it some wd40 to keep it from getting stuck again.
chirp187
Aug 7, 2011 10:13 AM
mikee111
Jun 30, 2010 07:10 PM
kmanracing24
Jul 27, 2009 04:36 PM
Turboedsupe
Apr 13, 2006 11:08 PM
