Ganged headlight/starter switch
Old Aug 6, 2011 | 08:06 PM
coldflood's Avatar
Default Ganged headlight/starter switch
I'm considering using a 20v on/off switch from wally mart to replace the starter switch to save myself some money. I noticed that theres a ganged switch inside the switch (which I already have taken apart) that opens the circuit to the headlight during start. What I basically want to know is if i just crimp the two wires together, which would leave the headlight on during start, would there still be enough electricity going to the coil to energize it and bridge the gap between the battery and the motor?
Old Aug 7, 2011 | 11:39 AM
Would there be power to the starter, yes. Would it be enough to start the bike is hard to say for sure. The Starter draws a huge amount of current to turn the engine over. It's the single largest draw on the battery. The headlights are second. If you bike starts every time, the first time, you may get away with it for a while.
I would recommend against it. I'd search ebay for a replacement. Since you've already taken the switch apart, you realize how simple of a device it is. You might be able to take parts from another year and model of bike to repair your switch (depending on what's wrong with yours). Another solution might be to go to Radio Shack and look for a better switch. One that is a Double-Pole-Single-Throw design which will allow you to keep the circuits separate, as well as turn one off and the other on.
coldflood
F2 Tech
Aug 7, 2011 09:18 PM
junker1244
Apr 3, 2011 07:39 PM
spoolie25
Mar 27, 2011 07:10 PM
Survivalism
Jan 29, 2011 10:18 PM
packdog
Feb 27, 2009 05:51 PM
