Fuel Tank leaking
Old Apr 29, 2007 | 11:56 PM
Jaybird180's Avatar
Default Fuel Tank leaking
Hello forum,
In the process of doing my winter project, I wanted to take a look at my fuel filter and so I removed it from the bottom of the tank. It appeared to drop back in place without any binding or problem. When I put fuel in the tank (after remounting on the bike) it was leaking profusely around the seal (see #20)
Anyone have more experience than I on this? Do I need some kind of sealant or is the seal a one time use item?
Old Apr 30, 2007 | 12:42 AM
bikenut's Avatar
Default RE: Fuel Tank leaking
You're supposed to always use a new seal for that. You're also supposed to tighten the bolts in an alternating sequence to make sure that it gets compressd evenly. If you number the screws clockwise, with the ones on the side being 3, and 6, the sequence should be 1,4,2,5,6,3. Just like a 6-lug wheel. (I hope that makes sence) Torque spec is 9 lb-ft.
Old Apr 30, 2007 | 12:59 AM
Joker_114th's Avatar
yep get new one,unless you like flame a permanent flame job.Ouch!!!!
Old Apr 30, 2007 | 11:58 AM
Jaybird180's Avatar
I recall some kind of sticky stuff when I took it off. I'm just hating to get a new one, gonna take TIME[:@]. Is there a shortcut?
Old May 1, 2007 | 02:06 PM
Tahoe SC's Avatar
yup there's a short cut. swap tanks with someone who's not using it, with the pump and all intact...
DO IT RIGHT MANG...unless you want to be a potential fireball waiting to happen.
Old May 1, 2007 | 04:52 PM
Jaybird180's Avatar
Of course you know I'm going to do it right. I called the dealer yesterday and had the rush me a new gasket. I was just venting that's all.
It should be here tomorrow.
Old May 1, 2007 | 07:03 PM
Tahoe SC's Avatar
oh look everyone...it's jay!
muahahaha...make sure you torque it correctly. it's a very sticky gromet. while you're at it might as well change the fuel filter.
Old May 3, 2007 | 12:08 AM
Jaybird180's Avatar
What the hell[:@]
I got the base gasket...start torqueing it down to 9ftlbs and the sucker still leaks....
Old May 3, 2007 | 01:01 PM
Tahoe SC's Avatar
did you clean and check the mating surface or what? make sure that fury copper mesh is out of the way.
did you follow the pattern?
psss...i had to torque mine more than specified. think they all at 12 or something.
Old May 3, 2007 | 03:20 PM
Jaybird180's Avatar
I'll check it again tonight. Heck, my torque wrench may be wrong for all I know. I think I may have put too much torque on it or the threads were weak. If I can't figure it out, I'm just gonna take it to the dealership (one of the mechs owes me a favor anyways). Worse case, I'll get a new complete tank.[]
Mulkxican88
Nov 14, 2013 05:23 PM
David Van Onselen
Sep 21, 2013 04:24 PM
rockstar_22
Apr 11, 2010 12:24 AM
CBRfenatic93
Mar 9, 2010 01:03 AM
jacobsdr
Jan 2, 2007 08:01 AM
