Fuel System Cleaners
RE: Fuel System Cleaners
When I used it on my car, I put some in the crank for a couple hundred miles ( max, because it thins the oil), then after that couple hundred miles I sucked some in a vac line, let the car sit for 20 mins, started the car back up and watched the smoke show. It all burned off, then changed the oil, and was good too go. I would ASSUME its similar on a bike.
i use seafoam in my old mustang
and my jetskis every summer
an entire can is a little much for a bike so at the beginning of each summer i will pour a few ounces in the tank and then a cap full into each velocity stack
it definetly keeps the valves cleaner when you look through the velocity stacks
ORIGINAL: baxsom
Fuel additives have to be used as a maintenance product, so you should add them every so often from when the bike is still somewhat new. They aren't like liquid gold or anything that will magically fix your carbon coated valves or gummed up injectors. I'll put ina vote for Seafoam as well, but just in the fuel tank!
