fuel pump
Old Sep 3, 2007 | 01:16 PM
one_sick_stang's Avatar
Default fuel pump
Will a honda f3 fuel pump ( on tank ) fit onto a 1993 honda cbr f2 without any issues. Mine went bad and I'm having no luck finding one for a f2. I have found one for a f3 but don't want to order it unless I know it's going to fit thanks once again.
Drew
Old Sep 3, 2007 | 04:16 PM
demonchild's Avatar
Default RE: fuel pump
Does the f2 have a fuel pump? Why do you think the fuel pump went bad?
Old Sep 3, 2007 | 05:09 PM
Not sure if it did or not and I'm talking about the pump ( at least I think thats what it is one the bottom of the tank not sure u can switch from on the res and off that piece connect to the filter) The filter in the tank was old and had a tear in itand it sucked some rust into it and clogged I took the part apart and blew it out but I'm re-doing this bike anyway and not wanting to risk having more damage done,so I'm just going to replace it. All I was wondering is if the f3 part will fit on mine? thanks.
Old Sep 3, 2007 | 05:14 PM
found out its called a petcock it's the fuel valve sorry for any confusion new to bikes.
Old Sep 3, 2007 | 07:46 PM
demonchild's Avatar
I am failrly sure that the petcock will not interchange between the f2 and f3. The fuel systems, IIRC, are completly different.
Old Sep 3, 2007 | 11:02 PM
Ok thanks alot didn't aim to throw u off on the fuel pump thing just wasn't sure ( drag racer here) I should have done some more research before I made myself sound dumb. Thanks again
Old Sep 4, 2007 | 12:12 AM
demonchild's Avatar
Not a problem. Everyone starts somewhere. It just happens that I started a lot earlier than others with mechanics.
Old Sep 4, 2007 | 12:15 AM
demonchild's Avatar
I just checked the part numbers. The petcocks do not have the same part numbers and the setup looks to be different, so to the best of my knowledge, I would have to say that they are not interchangeable.
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
