Fuel problem?????
Old Sep 8, 2009 | 11:36 PM
gwjvw's Avatar
Default Fuel problem?????
Hello to all,my 1st post! :-)
Yes i have a problem,i just bought this bike with 360 miles on it,2006 cbr600rr,Mint mint showroom cond from a friend,he never rode it and decided to sell it.
Heres the problem, sometimes while riding it will sputter,if i throttle it,it totally cuts out,,,so i let off back to normal and it goes,but still goes in and out. I go as far as i can untill my speed drops to low,(it likes really high gear and very low rpms to not sputter,but will sputter in time) and i pull over shut the bike off wait a sec or two fire it up and fly at 140,100,70mph whatever,could be 60,50,20,2 miles down the road it does it again so i do it all over again ,turn it off and etc,,,,the gas wasnt really stinky but you could tell it was old!When i got it i think it was the 2 or 3rd tank ever in the bike and had 1 bar left on the gauge,filled with 91 and rode it,i have tryied the fi cleaner but didnt help,its only done it once on the street but many many times on the freeway. Make me just want to sell it! It for sure has a problem, I rode to work (63 miles) and i think i had to pull over 9 times to make it home errrr Thanks all
Old Sep 9, 2009 | 10:03 AM
MartiniRossy's Avatar
Fuel filter partially restricted maybe?
Old Sep 11, 2009 | 07:33 PM
gotcbr's Avatar
Yep, check the fuel filter.
Old Sep 11, 2009 | 07:42 PM
cbrnub's Avatar
Yeah. If not, could be a vacuum leak or your fuel pressure regulator.
Old Sep 11, 2009 | 08:00 PM
Kuroshio's Avatar
Start with the plugs. 3 tanks of gas in 3 years, my guess is that the plugs have fouled from the rides + stale gas.
Old Sep 12, 2009 | 10:59 AM
gwjvw's Avatar
Is the fuel filter in the tank?,,also how does bad gas clog it up? ..Rode it all day yesterday and it didnt do it,but i know it will many times untill i fix whatever it is.
Old Sep 12, 2009 | 12:29 PM
justasquid's Avatar
when gas goes bad, it turns to what is commonly called varnish. this varnish will sink to the bottom of the tank, the lines, fuel pump or filters. It is so thick, it cloggs up what ever it build up on, so you end up with a restricted gas flow. Carbed bikes are much worse for the condition, but it can also wreak havoc on fuel injected bike as well. gas can start to go bad in as little as 3 months. so, when the guy only ran a tank a year, the previous years varnish was probably still in the bottom of the tank and it just built up every year. You just happen to be the lucky one that has to deal with his lack of taking care of his bike.
I agree with the comments, I'd replace the plugs and filter. And if you havent already, replace the oil. that is extremely hard on a bike to only have that many miles in that many years unless the guy maintained it really well. But, I'd bet he hasn't. The bike is probably still on the original break in oil. ... not good. replace the oil, then change it again at 1000 miles. then you should be good to start scheduled oil changes.
My guess is your still sucking in varnished gas from the tank every once in a while and thats causing your problem. Run a can of Seafoam fuel system cleaner through it. It will help treat the gas that is in there while cleaning out your system.
Old Sep 13, 2009 | 03:00 PM
gwjvw's Avatar
Thank you!!!
kwood
Jun 1, 2020 09:53 AM
BitRex
Nov 1, 2015 09:40 AM
Paranoia
Sep 4, 2011 12:26 AM
durty116
Jul 7, 2009 05:38 PM
SVTFire
Aug 29, 2006 07:57 PM
