fuel injection light after slipon install
So I just installed my scorpion slip on last night. (Sounds incredible btw) but on my way to work this morning my fuel injection light came on. It was fine until I got over around 8k rpms. That's when it seems to come on. After shutdown and restart it goes away. My question is how do I get the light to go away?
well its either a 33 or a 34, depending on weather or not you count the first fast blink. if you do count it, 34, if not, 33.
im sure it has to do with the removal of the exhaust valve for my slipon install, my question is how to i make the light not come on for a system that is no longer installed.
If you rotated the pulley on the servo from its home position when you removed the cables it will cause a fault light to appear, even if the servo is still plugged in.
On my 1000RR the home position is when the notch is pointing toward the rear of the bike.
Freddy2121
11-03-2008 10:29 AM
Freddy2121
10-30-2008 04:47 PM
