Front sprocket - is this normal?
Old Sep 2, 2007 | 09:35 PM
younghutch's Avatar
Default Front sprocket - is this normal?
I replaced the stocker with an AFAM 15t front sprocket and after installation and proper torquing of the boltthe new sprocket has a very small amount of left-to-right play (maybe 1/16th"). I didn't notice any sort of a spacer or additional washer to bridge the gap between the sprocket nut washer and the edge of the sprocket itself.
Is this normal?
edit - bike is a 2006 F4i
Old Sep 2, 2007 | 09:43 PM
doncollins's Avatar
Retired Administrator
Default RE: Front sprocket - is this normal?
NO...
I have the same sprocket and it fits tight. Something is wrong. Take it off and flip it to see if there is an offset on one side.
Old Sep 2, 2007 | 09:47 PM
younghutch's Avatar
I tried that & got the same result. It's as though the spline housingis thinner overall than the stock. I have an AFAM 520 and a 525 and they both do the same thing. Did I miss a spacer or something when I removed the stocker?
Old Sep 2, 2007 | 09:49 PM
doncollins's Avatar
I don't recall having a spacer on mine... wait a minute, let me look at something.
Old Sep 2, 2007 | 09:55 PM
doncollins's Avatar
Here's an exploded view of the 2006 F4i setup.
# 18 is the sprocket, does this show any missing parts? IF not, then I'd guess you have the wrong sprocket for your bike.
Old Sep 2, 2007 | 09:59 PM
younghutch's Avatar
Nope - looks like everything is there that should be there...back to the parts counter. Grrrr.
Thanks, Don.
Old Sep 2, 2007 | 10:03 PM
doncollins's Avatar
Better safe than tear up your bike. Can you compare the two sprockets? Find a harbor freight near by and pick up a cheap caliper to meassure with. Or use something like a work bench vise. Set it so the factory sprocket slides through and see if the new one has play.
Old Sep 2, 2007 | 10:10 PM
sixhundredrr's Avatar
Good job helping the guy out. It's nice to see.
Old Sep 2, 2007 | 10:24 PM
doncollins's Avatar
I do what I can when I can find time to use the PC anymore.
And friends don't let friends damage Hondas.
Old Sep 3, 2007 | 11:08 AM
jmdaley's Avatar
Amen to that.
Congee
Mar 12, 2013 02:09 PM
Viking
Jul 24, 2007 10:51 PM
