front springs
Old Mar 17, 2006 | 04:38 PM
GRUNT_Jarksbro's Avatar
Default front springs
I want to replace the front springs on my 04 f4i
What spring rate would I need?
This is for street riding and not track
I weigh 165lbs. (without gear)
Old Mar 17, 2006 | 04:40 PM
Tahoe SC's Avatar
Default RE: front springs
.85 i would say...check ohlins site as well as racetech.
Old Mar 17, 2006 | 04:44 PM
ORIGINAL: Tahoe SC
Looks like you were correct
Thanks for the info
from racetech website
Rider Weight: 165 lbs.
Recommended Spring Rate: 0.815 kg/mm (use closest available)
Stock Fork Spring Rate (measured): .660 kg/mm (stock)
Available FRSP S3732 Series Springs are:
Old Mar 17, 2006 | 09:31 PM
Tahoe SC's Avatar
hey but check it mang...their spring rating is actually a bit less than...say...ohlins.
i went with .85 up front, which is for a 165, but know that full gear, you'll be more...but it's plenty stiff for me so it's all good.
Old Mar 20, 2006 | 02:47 AM
Whippet Goode's Avatar
You might seriously consider other sources like Aftershocks, GP Suspension, Lindemen, Traxxion Dynamics, etc. These folks tend to handle better products and/or more actual racecraft knowledge.
Cheers
Old Mar 20, 2006 | 12:31 PM
Tahoe SC's Avatar
yea race tech is blah...ohlins is good...
BAXR8
May 25, 2015 08:28 AM
ldaxh33
How-To: Mechanical
Apr 16, 2011 12:18 PM
stynkmonkey
Feb 22, 2008 09:07 PM
MRJaggu
Mar 11, 2007 07:16 PM
